Sony Vaio VPC-F13Z1E/B : Fan noise?
profile.country.en_GB.title
greektranslator
Hello everyone. I am thinking of buying Sony Vaio VPC-F13Z1E/B in the coming days, but I see alot of complaints online about previous models regarding a whistling or other noises coming from the fan. Has anyone of you used this laptop? Is that problem affecting you? Would you suggest I should go for it?
Thank you all in advance!
Dimitris
Tags (3)
1 REPLY 1
profile.country.tr_TR.title
selcukdursun48
hi Dimitris
İm using same laptop and i have a same problem dont worry  hdd is 7200 RPM and i think used bad fan..i will buy SSD hdd and maybe new good fan. tace kare
