Battery problem
AhmetTR
Battery problem
%100-%97 fast running out, %15-%11 and %11-%8. İn stamina mod.So between the running out very quickly. I don't know that. İs that normal? Please help.
TR: Şarjım %100den %97ye çok çabuk iniyor ve %15ten %11e çok çabuk geçiyor. Diğer yüzdeler normal. Stamina modda böyle. Bu normal mi yoksa arıza mı var?
Tags (1)
7 REPLIES 7
Uliwooly
Could you give us more info, how fast is your battery draining, also go to settings > power managements > battery > check what is draining your battery. Also check the graph.
AhmetTR
Uliwooly
I can't see the pictures until they get approved, you could wait or upload them to box or Dropbox and post the link here
Uliwooly
your WiFi its on and most likely an app or apps are creating this battery drain.
AhmetTR
Thank you
Uliwooly
Anytime
