I've updated my nordic Z3 to Lollipop 5.0.2. Now there's a guest account which intention should be that the user of this account does not get access to your files/data. Unfortunately it seems Sony didn't implement mounting of the sd card correctly. Every user (even guest) has access to the same content of the sd card! Means if you save your photos of the main account on sd card, also the guest can see your photos! Probably same is valid for app data which you move to sd card.
Did someone else face this issue? Are there any special settings to solve this issue?
I'm not aware of this so can't comment however you could contact Xperia care and see if it is known or they should be able to forward this or provide details on how to forward this - http://www.sonymobile.com/global-en/support/contact-us/
Thommo, thanks for your quick reply. I've contacted the xperia chat. This issue will now be forwarded to the technical staff. Hopefully they will find a solution.
