BDP-S1100 problems with opera apps and SEN apps.
radiaz12
Has anyone else had trouble following the recent upgrade where the S1100 blu-ray player doesn't run opera apps anymore? And when you try to open a SEN app, it says 400 bad request.  I've been considering trying to re-upgrade with a cd using the UPDATA_M1R0138.ZIP I downloaded from the Sony website, but I'm afraid to brick the player.  I haven't found enough technical support to guide me through the process.
Any help would be appreciated.  I'm super frustrated because I really wanted to be able to use some of the apps.
20 REPLIES 20
WalterTattersall
Switched it on last night and got a message to say an update was available.  Downloded it and bingo everything now working - Demand5, Opera App store and all the Apps are working as they should.  Thanks!!
